Publish Intents in IBA Center
Published intents are displayed in the Published Intents pane as a table.
- Intent Name: A link to the published intent. You can click the intent name to view the intent details.
- Location: The location where the published intent is stored in the system.
- Publisher: The username of the user who published the intent.
- Published Time: The time when the intent is published.
You can perform the following two operations from the drop-down menu of a published intent item:
- Click View Details to view the published intent details in View-Mode.
- Click Unpublish to unpublish the intent and remove the intent from this pane.
Publish Intents in Batch
Under the Published Intents tab, you can publish intents in batch.
- Go to IBA center>Published Intents.
- Click + Publish Intents.
- In the Select Network Intents dialog, select some intents or folder of intents to publish by checking the checkbox of the intent/folder.
The following two options help to filter intents before intent selection.
- Show Intents with Template Qualifications Defined Only: If you select the checkbox to enable this function, all intents that can be used as template are filtered and displayed.
- Show Published Intents Only: If you select the checkbox to enable this function, all the published intents are filtered and displayed.
- Click OK to publish selected intents. The published intents will be added under the Published Intents tab and listed under the Published Intents pane of a Map having the same device as the published intent.
See also
