Function Portal
Function portal is a web portal of the NetBrain System, carrying some features of the NetBrain System, including Map and Data View. The Function Portal enables external users with no NetBrain System account to access some system functions to collaborate with others. External users can log in to the function portals with portal user accounts or access codes, which do not occupy seat licenses.
Main User Flow
Complete the following steps to use Function Portal for collaboration.
  1. Publish a Function Portal
  2. Log in to Function Portal
  3. View Dynamic Maps through Function Portal
  4. View A/B Path Result and Calculate Live Path
  5. Search One-IP Table and Map Devices
Function Portal Use Cases
You can leverage the features of the predefined function portals to visualize the networks and carry out collaborative troubleshooting. The following cases are several typical function portal use cases.
  • With Function Portal, the power user can publish selected data (maps/paths/One-IP table/limited data views on map) to different teams.
  • The user may have limited seat licenses. The power user can divide the domain data into smaller function portals and enable access codes for logging in to Portals so that external users can access the corporation’s data without seat licenses.
  • The map is a key function for documenting the network technologies. The power user can create a set of function portals with the map features for the key technologies, application flows, sites or secure domains to aggregate Networks.
