Function Modules
NetBrain includes the following three add-on function modules:
Note: Each module needs to be purchased separately. |
- Application Assurance Module (AAM) provides an integrated solution to manage, monitor, and troubleshoot network applications by combining the application-aware paths with NetBrain automation features. Value-added features of AAM include:
- Application Manager
- Golden Path
- Application-Aware Monitor
- Change Management Module (CM) provides a comprehensive network change management solution to create, approve, deploy and validate complex network changes. Value-added features of CMM include:
- Change Management Runbook
- Schedule and Triggered Network Change
- Preventive Automation (PA) provides the Intent-Based automation solution, including Interactive Automation for troubleshooting, Packaged Intent Automation as Interactive Service, running Automation for Network Assessment, Machine-to-Machine running of Automation.
All functions of AAM and CM require the corresponding module license. However, you may run the automation to a certain limit without a PA license for PA-related functions. The following table summarizes the functions that will be fully or partially restricted for the users without a PA license:
- There are no restrictions on NI/NIC creation.
- NI/NIC execution (both triggered via API and interactive execution, including running NI inside API stub) will be metered daily, and there are quotas per Domain.
- Preventative automation can be set up without the PA license, which includes: 1) Define AM probe; 2) View Trend chart; 3) View PA dashboard.
