Filter Recommended Automation
You can use the following types of filters to narrow down the list of the desired recommended Automation (s):
Type
You can filter recommended automations by type.
Tag
If tags are assigned to the Data View Template, Runbook Template, Network Intent and Network Intent Cluster, you can leverage tags to filter matched recommended Automation.
Note: by default, the system selects All to display all recommended Automation (s) regardless of whether it has assigned tags. |
Keyword
You can input keywords to match the Data View Template, Runbook Template, Network Intent, Network Intent Cluster and Hypothesis.
