Export Map to Word Document
Follow the steps below to export a map to Word:
- On a map, click Map > Export > Word from the map toolbar.
- In the Export to Word dialog, enter a document name and select a location for storing the word file.
In this dialog box, you can also:
- Select the map pages to be exported by selecting the checkbox of the pages.
- Filter map devices whose data will be exported to Word document. Click the
icon to display the Select Devices dialog, select a device from the left pane, then click the
icon to add this device.
- Select a data view for the map to be exported.
- Click Export.
Tip: Click Advanced Settings to customize the Word template (such as logo, author, and company name) and the contents of the document. See Settings for Exporting a Map for more details.
- To find the exported document, click Files on the Taskbar and locate the folder where you save the document.
