Setup Auto Intent in IBA Center
Auto Intent tab in Intent Based Automation Center (IBA Center) is a central place where power users can make definition to Auto Intent for end users.
- Define Folder Structure to Organize Automation Assets in Auto Intent
- Enable Intent Templates for Auto Intent
- Enable ADT Assets for Auto Intent
- Auto Intent Profile
Where to Start?
Go to Intent Based Automation Center > Auto Intent to perform the relevant operations described in this chapter.
Key Components of Auto Intent Tab in IBA Center
Generally, power users will operate on the Auto Intent tab in IBA Center. The key components of the Auto Intent Tab are described below:
- Build a folder structure to display assets in Auto Intent Pane: The folder structure contains the assets to be displayed in Auto Intent.
- Enable intent templates for Auto Intent: After adding an intent template, power users can define the intent template in the right pane, e.g., replicating intent templates, customizing the macro variables.
- Enable ADT (Automation Data Table) Intents/Maps/Paths for Auto Intent: After adding ADT intent, power users can define the ADT intent in the right pane, for example, defining the relevant logic to deliver desired intent/map/path.
