Edit Drill Down Report
For all the charts displayed on the Intent Dashboard, an option is provided to edit the drill-down report and action by selecting a chart. To edit, click Edit Drill Down Report and Action to open its interface window.
Use the left side column of the window to control the displayed columns of the drill-down report. The right side will display sample data for the drill-down report based on the fields in the column.
The report will be constructed based on your settings in the chart, using fields from the intent result or intent device result. The default columns will be provided based on the selected chart type. Please refer to the content below.
  1. Click + Add Columns to choose fields from the intent result or intent device result to display in the drill-down report.
  2. Reorganize the table columns by drag and drop action of the fields added.
  3. Select a specific field and set the drill-down action. Supported drill-down actions include:
    • Open Intent Details
    • Open Device Details
    • Open Configuration File
    • Open Diagnosis Tree
    • Open Map
