R12 Publication-2025July16 Device Access Control in Golden Config Pane If the current user does not have the privilege to access the current device, the device data such as config file and Config-let will not be loaded in this pane. Consequently, no Golden Config Check result will be shown. Check Config Against Golden Rule Golden Feature
