Define Recommended Automations
Recommended automations are a group of tasks elaborately designed to analyze and troubleshoot a certain network issue, building a bridge to connect dynamic maps with network automation for diagnosis and troubleshooting.
The action input for each recommended automation is script-based. If you want to customize input parameters in the script to ensure actions can run as expected, please refer to The Syntax for Defining Action Input and Syntax for Defining Target Devices.
Action Level and Device Scope
The system provides two levels of recommended automations in DVT definition:
- Template level — perform actions targeting all devices on a map. Recommended automations at the template level are displayed unconditionally.
- Device level — perform actions targeting specific devices/interfaces only, and its display is controlled via conditions.
The following table shows whether action input and device scope can be customized at each level of recommended automations.
| Recommended Automation Level | Support Customized Action Input? | Support Customized Device Scope? |
| Template Level | √ | |
| Device Level | √ |
Tip: Action input for most recommended automations can be customized. See Syntax for Defining Action Input for more details. |
Tip: To customize device scope for recommended automations at the device level, see Syntax for Defining Target Devices for more details. |
Available Recommended Automations at Both Levels
The following table introduces the recommended automations that can be defined at the template level and device level.
| Recommended Automation | Template Level | Available at Device Level |
| Data View Template | √ | √ |
| Qapp | √ | √ |
| Gapp | √ | √ |
| Network Intent | √ | √ |
| Overall Health Monitor | √ | √ |
| Execute CLI commands | √ | √ |
| View Device Data (including Configuration File, Route Table, MAC Table, ARP Table, STP Table, NDP Table and NCT Table) | √ | |
| Ping | √ | |
| Traceroute | √ | |
| Calculate Path | √ | |
| Compare | √ | √ |
| SPOG URL | √ | |
| URL | √ | √ |
| Runbook Template | √ | √ |
| Verify Application | √ | √ |
