​​​​​Cryptographic key Rotation
The cryptographic key is a string of characters used within an encryption algorithm for changing data so that it appears random. Like a physical key, it locks (encrypts) data so that only someone with the right key can unlock (decrypt) it. In the NetBrain System, you can manually update the cryptographic key.
Complete the following steps to update the cryptographic key.
  2. On the System Management page, select the Advanced Settings tab.
  3. In the Cryptographic key Rotation area, click Update.
    Graphical user interface, text, application, chat or text message
  1. Enter a KVAP value in the pop-up dialog box. And then click OK.
  1. Click Save.
