Differences Between Visual Parser and Advanced Parser
Parser is designed to allow users to create a Parser with no or little coding for no-code automation. The Parser in the prior versions is renamed as Advanced Parser.
Differences between Visual Parser and Advanced Parser
The following table lists the feature comparison between the Visual Parser and Advanced Parser:
| Feature Category | Visual Parser | Advanced Parser |
| Start/End Line | √ | |
| Text Replacement | √ | |
| Real-time highlight variable definition and comment | √ | |
| Line pattern syntax highlight and intellisense | √ | |
| Paragraph nested table | √ | √ |
| Paragraph nested paragraph | Multi-level nesting with parent line | Multi-level nesting |
| Supported Line Pattern Syntax |
| Supported variable types |
| Allowed ID lines | Multiple ID lines | Only one ID line |
| Supported Parser Type |
| Supported Data Type |
| Allowed Samples | Multiple samples | Multiple samples |
