Setup Triggered Automation
Follow the steps to configure TAF to trigger diagnosis from the IT system:
- Define Integrated IT System
- Define Incident Type to Classify Different Tickets
- Define Triggered Diagnosis
Note: The execution logs can be viewed in View Triggered Diagnosis Log.
NetBrain supports triggered diagnosis from external IT systems integrated with NetBrain, such as ServiceNow, Splunk, BMC Remedy. NetBrain also supports diagnosis triggered by Email.
