Clean Up Unassigned Site Members
Unassigned site members refer to devices that are not assigned to any sites in your domain. If a device cannot meet any criteria of a site definition or isn't manually added to a site, it will be treated as an unassigned site member. Unassigned site members would prevent the system from generating complete site maps.
  1. Log in to the Domain Management page and click Site on the Start Page to open Site Manager.
  2. In the Site Manager, click My Network in the site tree and then locate Site Definition on the target leaf site.
  3. Move the unassigned devices to the target leaf sites using the following ways
    1. Dynamic Search — improve the existing Dynamic Search, such as criteria search and Boolean expression. Click Search. See Dynamic Search for more details.
    2. Manually Add — click Add Devices Manually. Under the Site option, click Unassigned and then select target devices.
    3. A screenshot of a computer Description automatically generated
    4. Move devices to a site manually — Click Unassigned under My Network tree, and then select the Site Member tab. You can select a single device or multiple devices and add them to a site or device group.
  4. Graphical user interface Description automatically generated
  5. Repeat steps 1 ~ 3 to add more site members until unassigned site members are all cleaned.
  6. Graphical user interface, text, application Description automatically generated
  7. In the Site Manager, click Rebuild All Sites to rebuild the site topology. The Site Member pane opens automatically and lists the devices in the current site.
  8. Click Commit.
