Browsing Sites
A site is a geographical grouping of network devices, which can be used as device scopes, asset filters, and map/topology views. For example, you can divide your network into a hierarchy of sites based on country, state, city, region, and office location.
There are two types of sites in the system:
Container Site (
) — A parent site that contains leaf sites and other container sites. No devices are directly nested under a container site.
Leaf Site (
) — A child site that contains devices. The devices can be added manually or searched dynamically.
