Built-in Data View Templates (DVTs)
The system provides the following built-in data view templates for various purposes and scenarios, including routing and switching, security, quality of service, high availability and so on.
| Category | Built-in DVT Name | Branch Criteria | Supporting Variables | Drill Down Actions |
| Cisco ACI | Fabric Health and Faults [Cisco ACI] | - Traditional Device - Device Type contains Cisco ACI APIC; Cisco ACI Leaf Switch; Cisco ACI Spine Switch | Device Level: - fault_details1) - fault_critical - health_timestamp - health_change | Device Level: |
| Fabric Underlay Connections [Cisco ACI] | - Traditional Device - Device Type contains Cisco ACI APIC; Cisco ACI Leaf Switch; Cisco ACI Spine Switch | Device Level: - LLDP_Detail - CDP_Detail - port_channel_detail - vpc_detail | Template Level: | |
| Logic Node View [Cisco ACI] | Branch: BD - Traditional Device | Device Level: - tn_name - bd_mac - subnets | ||
Branch: Contract - Contract | Device Level: - provider_epg - consumer_epg - contract_detail - filters_detail | |||
Branch: EPG - EPG | Device Level: - tn_name1 - ap_name - ep_detail | |||
Branch: L2Out - L2Out | Device Level: - BD_extended - node_intf_table1 | |||
Branch: L3Out - L3Out | Device Level: - ospf_info - node_intf_table | |||
| High Availability | HSRP Overview | - Traditional Device (IPv4 Interface) - Config File contains 'standby' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - hsrp_groups1) - ip_int_brief2) Interface Level: - group1 - authentication - priority | Template Level: - Compare the Configuration File in two data sources - Understand and Troubleshoot HSRP Problems in Catalyst Switch Networks - View the Spanning Tree Overview Device Level: - Execute CLI Commands show standby; Ping the device1) - Execute CLI Commands show ip int brief and show ip int | in line|list; View the ARP Table2) |
| Quality of Service | QoS Overview | - Traditional Device (IPv4 Interface; Physical Interface) - Config File contains 'service-policy' and Config File contains 'policy-map', and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - service_policy1) - class_map2) - mls_qos_intfs Interface Level: - direction | Template Level: - Compare the Configuration File in two data sources Device Level: - Execute CLI Commands show policy-map1) - Execute CLI Commands show class-map2) |
| Routing | EIGRP Overview | - Traditional Device (IPv4 Interface) - Config File contains 'router eigrp' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - eigrp_neighbor_detail1) - eigrp_intfs (paragraph) 2) - RouteTable3) Interface Level: - peers (int) - split_horizon (string) - pending_routes (string) | Template Level: - Compare the Configuration File in two data sources - Show log include INPUT [Cisco IOS NXOS ASA] - View the EIGRP Troubleshoot Guide Device Level: - Execute CLI Commands show ip eigrp neighbor detail; Ping the device; View the MAC Table1) - View the ARP Table; Execute CLI Commands show ip eigrp interface2) - Execute CLI Commands show ip eigrp topology3) |
| IP BGP Overview | - Traditional Device - Config File contains 'router bgp' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - rid - bgp_neighbors1) - bgp_filter_detail2) - bgp_rib_failure3) | Template Level: - Compare the Configuration File in two data sources - Show log include INPUT [Cisco IOS NXOS ASA] - Apply DVT IP BGP Prefix Instance Device Level: - Ping the device; Use Traceroute to discover and map a routing path; Execute CLI Commands show ip bgp neighbors, show tcp brief all1) - Execute CLI Commands show ip bgp neighbors, show access-list, show ip prefix-list, and show route-map2) | |
| IP BGP Prefix Instance | - Traditional Device - Config File contains 'router bgp' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - bgp_paths1) - bgp_filter_detail2) - RouteTable | Template Level: - Compare the Configuration File in two data sources Device Level: - View the BGP Advertised-route Table1) - Execute CLI Commands show access-list, show ip prefix-list, and show route-map2) | |
| ISIS Overview | - Traditional Device (IPv4 Interface) - Config File contains 'router isis' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - clns_neighbors1) - clns_interfaces2) - level_lsp_database3) - isis_protocol_process4) Interface Level: - level_1_metric - level_2_metric - l1_adj_count - l2_adj_count | Template Level: - Compare the Configuration File and Route Table in two data sources - Show log include INPUT [Cisco IOS NXOS ASA] Device Level: - Ping the device; View the ARP Table; Execute CLI Commands show isis neighbor1) - Execute CLI Commands show clns interface2) - Execute CLI Commands show isis database3) - Execute CLI Commands show isis process4) | |
| MPLS L3VPN | - Traditional Device (IPv4 Interface) - Config File contains 'vpnv4' and Does not contain 'route-reflector-client'; Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - rd (string) - exp_map (string) - imp_map (string) - interface (paragraph)1) | Template Level: Device Level: - Show log include INPUT [Cisco IOS NXOS ASA]; Show run section INPUT [ Cisco IOS NXOS ASA]; Execute CLI Commands show ip protocols vrf and show ip vrf interface1) | |
| Multicast Overview | - Traditional Device (IPv4 Interface) - Config File contains 'ip pim' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - pim_neighbors1) - pim_intf2) - rp_mapping3) - igmp_groups4) Interface Level: - version - dr_priority - dr1 - nbr_count | Template Level: - Compare Configuration File in two data sources - Show log include INPUT [Cisco IOS NXOS ASA] Device Level: - Execute CLI Commands show ip pim neighbor; View the Route Table1) - Execute CLI Commands show ip pim interface2) - Execute CLI Commands show ip pim rp mapping and show access-list3) - Execute CLI Commands show ip igmp group4) | |
| OSPF Overview | - Traditional Device (IPv4 Interface) - Config File contains 'router ospf' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - ospf_nbrs1) - ospf_intf2) - ospf_process3) - RouteTable4) Interface Level: - cost - nbrs_fc - intf_state | Template Level: - Compare the Configuration File in two data sources - Show log include INPUT [Cisco IOS NXOS ASA] Device Level: - Ping the device; Execute CLI Commands show ip ospf neighbor detail1) - Execute CLI Commands show ip interface brief, show ip ospf interface, and show ip int | in list|line2) - Execute CLI Commands show ip ospf and show ip ospf database self-originate3) - Execute CLI Commands show ip route summary and show ip route ospf; Show ip route INPUT [ Cisco IOS NXOS ASA]4) | |
| Security | Access List [Cisco IOS] | - Traditional Device (IPv4 Interface) - Config File contains 'access-list,' and Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - acl_list1) - acl_detail - intf_table2) - ACL Tips Interface Level: - in_acl - mtu - out_acl - nat | Template Level: - Compare the Configuration File in two data sources Device Level: - Execute CLI Commands show access-list1) - Execute CLI Commands show ip interface2) |
| Switching | MPLS LDP | - Traditional Device (IPv4 Interface) - Config File contains 'mpls ip' and 'ldp'; Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - ldp_id (string) - ldp_authentication (paragraph) - ldp_nbrs (paragraph)1) - mpls_ints (table) | Template Level: - Compare data in two data sources Device Level: - Show log include INPUT [Cisco IOS NXOS ASA]; show run section INPUT [ Cisco IOS NXOS ASA]; Execute CLI Commands show run | i router-id, show tcp brief all, show mpls ldp discovery, and show mpls ldp neighbor1) |
| Spanning Tree Overview | - Traditional Device - Config File contains 'switchport' and Config File contains 'spanning', and Device Type contains Cisco IOS Switch | Device Level: - root_bridge - spanning_tree_root - vlan_intfs - stp_features | Template Level: - Compare the Configuration File and STP Table in two data sources - View the Spanning Tree VLAN Instance | |
| Spanning Tree VLAN Instance | - Traditional Device (Physical Interface) - Config File contains 'switchport' and Config File contains 'spanning', and Device Type contains Cisco IOS Switch | Device Level: - bridge_address - bridge_priority - stp_vlan Interface Level: - role - type - cost | N/A | |
| VMware | Infrastructure View [vCenter] | Branch: Legacy - Traditional Device (Physical Interface) - Device Type contains NSX Controller; NSX Distributed Logical Router; NSX Edge Security Gateway; NSX Manager; VM Host | Device Level: - ESXi Host Name - Memory Size - vCPU Number - UsedStorage_MB Interface Level: - Connected - Start Connected | N/A |
Branch: VDS - Vmware Distributed Virtual Switch (Port) | Interface Level: - Port Group - State - Connectee - Vlan | |||
| Operation View [NSX-V] | Branch: Branch1 - Traditional Device - Device Type contains NSX Distributed Logical Router; NSX Edge Security Gateway | Device Level: - edge_status (string) - ha_state (string) - publish_status (string) - system_status (string) | N/A | |
Branch: Branch2 - Traditional Device - Device Type contains NSX Controller | Device Level: - status (string) - nodeFailoverReady (bool) - connectivity_table (table) | |||
Branch: Branch3 - Traditional Device - Device Type contains NSX Manager | Device Level: - componentsByGroup_SYSTEM_components - componentsByGroup_COMMON_components | |||
| Operation View [vCenter] | Branch: Branch1 - Traditional Device (Physical Interface) - Device Type contains NSX Controller; NSX Distributed Logical Router; NSX Edge Security Gateway; NSX Manager; VM Host | Device Level: - overallStatus (string) - overallCpuUsage (int) - hostMemoryUsage (int) - guestHeartbeatStatus (string) Interface Level: - status (string) - startConnected (bool) - connected (bool) | N/A | |
Branch: Branch2 - Traditional Device (Physical Interface) - Device Type contains vSphere Distributed Switch | Device Level: - hosts_status_table Interface Level: - intf_status (string) | |||
| Generic | Infrastructure View | Branch: ACI - Fabric Node | Device Level: - Node Id - Model - Serial Number - Version | Template Level: - Compare the Configuration File in two data sources - Monitor the overall health of all devices via SNMP - Learn more about how to use NetBrain Device Level*: - Ping the device; Use Traceroute to discover and map a routing path1) |
Branch: Legacy - Traditional Device - Device Main Type contains Router; L3 Switch; Firewall; WAN Optimizer; LAN Switch; Load Balancer; Call Manager; WAP; WLC | Device Level*: - Mgmt IP1) - Model - Serial Number - Site | |||
| Network Table View | Branch: Legacy - Traditional Device - Device Main Type contains Router; L3 Switch; Firewall; WAN Optimizer; LAN Switch; Load Balancer; Call Manager; WLC | Device Level: - NDPTable1) - RouteTable12) - ARPTable13) - MACTable14) | Template Level: - Monitor the overall health of all devices via SNMP - View the training video to see how NetBrain delivers deeper network visibility, faster troubleshooting diagnoses and enhanced collaboration within IT teams Device Level: - View the NDP Table; Compare the NDP Table in two data sources1) - View the Route Table; Compare the Route Table in two data sources2) - View the ARP Table; Compare the ARP Table in two data sources3) - View the MAC Table; Compare the MAC Table in two data sources4) | |
| Overall Health Check | Branch: CiscoASA - Traditional Device (IPv4 Interface) - Device Type contains Cisco ASA Firewall | Device Level*: - one_min_cpu_usage1) - used_mem_utl2) - failover_unit3) - failover_interfaces4) Interface Level: - input_errors (int) - crc (int) - output_error (int) - collections (int) - one_min_input_rate_pkts - one_min_output_rate_pkts - one_min_drop_rate_pkts | Template Level: - Show log include INPUT [Cisco IOS NXOS ASA] - Show run section INPUT [ Cisco IOS NXOS ASA] Device Level*: - Execute CLI Commands show cpu usage1) - Execute CLI Commands show memory2) - Show log include INPUT [Cisco IOS NXOS ASA]3) - Ping the device; Execute CLI Commands show failover4) | |
Branch: CiscoIOS - Traditional Device (IPv4 Interface; Physical Interface) - Device Type contains Cisco IOS Switch; Cisco Router | Device Level: - intfs_table - five_min_cpu_usage - mem_util - cpu_table Interface Level: - input_errors (double) - crc (int) - output_error (double) - collisions (int) - mtu (int) - duplex (string) - tx_load (int) - rx_load (int) |
