Build Data View Template for Azure Network
Out-of-box, NetBrain enables you to monitor various Azure network data on a dynamic map by using the built-in Data View Template for Azure. This section focuses on explaining how NetBrain manages to visualize your Azure data. For how to use Data View Template, refer to Apply Data View Template.
In general, there are two kinds of Azure data that can be visualized:
  • Azure Infrastructure Data: this involves the basic information of Azure operational status, routing/security, tag information, and so on. See DVT for Azure Infrastructure for more details.
  • Azure Insight Metrics: this involves the monitoring metrics (usually data plane status) from the cloud-native monitoring tools, such as Azure Monitoring. See DVT for Azure Insight Metrics for more details.
To visualize the relevant data using Data View Template, you can leverage the following two types of data:
Built-in Data View Templates for Azure Infrastructure
This type of DVT shows the key data received from the Azure on a map, including monitor and the analytic results.
  • [Azure] Basic Info
This DVT displays the basic information or properties of an Azure resource. The different types of resources have different types of properties. For example, Address Space, Location, Tags, Resource Group of Virtual Network, or Provisioning State, Type of Load Balancer.
Also, this DVT includes Effective Route Table, Effective Security Rules, and User Defined Route Table associated with a network interface (NIC) or subnet level.
  • [Azure] Subscription Info
This DVT displays the subscription name and ID.
DiagramDescription automatically generated
  • [Azure] BGP Info
This DVT displays the BGP settings.
  • [Azure] TAG info
This DVT displays the TAG information.
图形用户界面, 应用程序, Word描述已自动生成
Built-in Data View Template for Azure Insight Metrics
  • [Azure Insights] Monitoring Azure Metrics
This DVT displays the pre-defined Azure Insight Metrics for different network objects.
