Logo
Build Column Group with Network Objects
Network Objects properties can be used to populate column group data. The corresponding four methods using network object properties are listed below:
  • Build Column Group with Map Properties
  • Build Column Group from Filtered Path Intents
  • Build Column Group from Intent Cluster
  • Build Column Group from Probes
Build Column Group from Formula Build Column Group with Map Properties
