R12.3 Project Publication -20250115
Use Match Pattern for Data Comparison
In intent diagnosis, when comparing the multi-line string of the device data with its last value/baseline value to detect changes, you can use the operator Match pattern. It can get comparison results, such as missing lines and extra lines. Furthermore, you can use such results in diagnosis message, CSV report, etc.
