R12.1 Project-2025/11/05
Port to Protocol List
The Port to Protocol List records the correlations between port numbers and protocols, which specify protocols and ports when calculating an A-B path.
Managing Port to Protocol List
  1. Log in to the Tenant Management page.
  2. On the Tenant Management page, click Icon
Description automatically generated and select Misc Configuration. Click the Port to Protocol List tab.
  3. Perform the following operations based on your needs.
  • Adding a new entry
    1. Click Add.
    2. In the Add Port to Protocol dialog, enter the protocol name, description, port number, and select the transport protocol from the drop-down list.
      Information Tip: To synchronize the added entry with NetBrain Server, select the Auto Update check box. If the system does not support the protocol you want to use, contact the NetBrain Support Team to report the issue.
    3. Click OK. The new entry is added to the list.
  • Exporting Port to Protocol List
    Click Export to export the list.
    Information Tip: The default location of the exported file is C:\Users\<your username>\Downloads.
