R12.1 Project-2025/11/05
Import a Map
You can export the device data from a map. Only the users with the Domain Management privilege can import maps into a domain.
- Import a Map — If the included devices already exist in your domain, the device data in your domain will be overwritten with the imported one.
Note: The customized properties will not be included unless the same attributes are also defined in the Global Data Repository of your tenant.
Import a Map
Follow the instructions below to import maps into the system.
- Click Files on the folder tree structure.
- Expand the folder tree, right-click the target folder and select Import Maps from the dropdown.
Note: You cannot import maps to the Shared with me folder.
- In the Import Maps dialog, click Select maps from your computer to select the map from the local maps and then click Open.
- By default, the Auto-rename duplicated map files option is checked. It will automatically rename a map file if a file with the same name already exists in the current directory. To skip duplicate maps instead of renaming them, uncheck this option.
- Click Import and then click Finish.
If you want to rebuild the topology instantly with the imported map data, click Domain Management in the notification box to execute a benchmark task. See Benchmark Task Settings for more details.
Tip: Successfully migrated EE site Maps are not listed in the Files pane.
Tip: If the map is an EE site Map, the editing rights will be unclaimed; otherwise, the user who imports a Map has their editing rights by default.
