R12.1 Project-2025/11/05
Enrich Basic Table Data with Column Groups
For a base table created via the application path, column groups can be added to cover more data. The system supports several methods to populate dynamic columns for a table. The table below briefly describes each of the methods. After the columns are added to ADT, you can build and update ADT data and add tags to the automation column and map column.
The following table describes the methods for building column group data.
Methods for Building Column Group
Description
Replicated Intent
Intent Templates (Device-based)
Replicate seed intent for specified devices in the current row and populate each cell with the replicated intent.
Intent Templates (Path-based)
Replicate seed intent for each path in the current row and populate each cell with the replicated intent.
Intent Templates via Other ADT (Device-based)
Filter matched NITs from a source ADT for device-based intent replication based on the seed devices in the current ADT.
Intent Templates via Other ADT (Path-based)
Filter matched NITs from a source ADT for path-based intent replication based on the path properties in the current ADT.
Formula
Device Properties
Add a column displaying the property value of the device in the same row.
Converting Function
Add a column by converting another column via special function, e.g. convert an IP column to a device column.
Network Objects
Map
Add a column with matched map from specified folders using devices in the same row as the matching key.
Path Intent
Add a path intent column using the intent name or intent tag as the filtering key.
Intent Cluster Member
Add an intent column with the matched members from intent cluster (NIC) using devices in the same row as the matching key.
Probe
Add a probe column using the devices in the same row as the matching key.
Data from Other Table
Another ADT
Copy columns from another ADT.
Imported CSV
Copy columns from CSV file.
ADT Dataset
Recurring Benchmark
Organize raw data from benchmark into ADT dataset for specified devices.
Imported CLI/Config Files
Import external CLI or configuration files into ADT dataset for specified devices.
Write Via Intent
Enable Intent to programmatically write to this type of ADT dataset column.
Interactive Retrieval
Define command and retrieve data interactively.
Information Note: The column groups are added after the base table is built.
