R12.1 Project-2025/11/05
Discover Azure Resources
Follow these steps to discover Azure networking resources via APIs:
Follow the steps below to discover the network data model in a NetBrain domain:
- In the Domain Management > Start Page, click Discover.
- Click Select API Servers to select the Azure API Server you just created.
- Click Start Discovery to start the Azure discovery. You can run the discovery task manually or schedule a discovery task to discover Azure resources.
- Wait till the discovery finishes. The number of discovered objects will be displayed.
