R12.1 Project-2025/11/05
Define Playbook
Use either of the following ways to define a playbook
Information Note Please follow Ansible’s best practice for the project structure/directory layout (only applicable to Sync Up Playbook from SCM):
https://docs.ansible.com/ansible/latest/user_guide/sample_setup.html#sample-directory-layout
https://docs.ansible.com/ansible/2.8/user_guide/playbooks_best_practices.html#directory-layout
Use or Install Ansible Role/Collection
One crucial way to organize your playbook content is Ansible’s “roles” organization feature. You can embed your role content in your project directory (Refer to https://docs.ansible.com/ansible/latest/user_guide/playbooks_reuse_roles.html for the best practice of setting up role directory structure) or trigger the installation of the roles/collections on Ansible by including the roles in a requirements.yml file and defining the file in your Ansible project directory.
You can trigger the installation of roles and collections from the same requirements.yml file. For the syntax please follow Ansible’s documentation: https://docs.ansible.com/ansible/latest/galaxy/user_guide.html#installing-roles-and-collections-from-the-same-requirements-yml-file
Information Note: if you are using older Ansible versions prior to (including) Ansible 2.9, to trigger the installation of collections, please contact NetBrain to apply a small patch.
Note: The requirements file path must be /roles/requirements.yml in your Git Ansible repo.
References:
Sample directory layout from Ansible Documentation:
Directory layout from Ansible’s best practice:
Syntax of installing roles and collections from requirements.yml file:
