R12.1 Project-2025/11/05
Configure Change Management Login
- On a map, right-click the target device, and select Change Management Login.
- To change the management IP address, select a new one from the Management IP drop-down list.
- To change the Telnet/SSH login credential or privilege login credential, click Available Username in the corresponding area to select the correct one.
Note: The shared credentials synchronized from the Shared Device Settings cannot be edited. See Network Change Credentials Management for more details. - Click Tune to test whether the device is accessible by using the new management IP or new credentials.
- Select whether to apply the credentials to other devices in a device group based on your needs.
- Click Yes.
- Select the check box for each item.
- Select a device group from the drop-down list.
- Click Apply to apply the settings to the devices in the selected device group.
- Click Submit.
