R12.1 Project-2025/11/05
API Data Retrieval Management
NetBrain engineers or Power Users can expand and manage the API data available to end users through API Data Category and API Data Retrieval.
API Data Category
The folder structure on the left side of the Select API Data to Retrieval dialog is defined on this API Data Category section.
- You can expand the Category and API Data for more technologies using the option +New Technology. For example: Expanding Cisco ACI's API Data can be defined in this Category structure.
- Both Import and Export functionalities are supported.
API Data Retrieval
NetBrain engineers will continuously add and adjust API Data, which will be delivered to customers through KC (Knowledge Cloud).
Using the API Data Category above and the definition of API Data here in API Data Retrieval, the following details are presented to end users in the Select API Data to Retrieve dialog:
- Tree structure on the left side.
- Description information and Reference URL displayed on the right side.
