View Triggered Automation Dashboard
Open Triggered Automation Dashboard
  1. Click Observability Dashboard> All> the Observability Tab> Triggered Automation Dashboard folder.
    Information Note: The Triggered Automation Dashboard folder is a built-in folder. Users can only open it and are unable to perform any other operations.
  2. Right-click Triggered Automation Dashboard and select Open.
A screenshot of a computerDescription automatically generated
  1. Summary Chart.
  2. The intent dashboards with the same Incident Type will be grouped into one chart. Each chart will display both device results and intent results.
    • The charts will be arranged in alphabetical order. (A-Z)
    • The intent dashboards within the chart will be arranged in chronological order.
    • You can click a green or red bar to open its drill-down report. The link for the incident is included in the drill-down report.
      Information Note: Each chart can display a maximum of 100 dashboards.
You can view triggered automation results at different time ranges.
