Visualize Physical Network by Device Type
Explore network objects, grouped by device type, and view their details and context maps in the Network Tree.
- In the NetBrain desktop sidebar, open Network.
- In the Category field, select Physical Network.
- In the View field, select Device Type.
- Expand the Device Type node to view device information.
Tip: The number next to each node indicates the number of its child nodes.
- Click Open Map to view the context map.
Tip: The context maps display the L3 Topology or L2 Topology.
- Click the Device Details pane to view the node’s detailed properties, interface and IP interfaces.
