View Common Intent
The Automation Insight tab displays the latest results of common intents.
Example: View the common intent Overall Config Check.
- It belongs to the category of General. (The category can be defined in Insight Manager.)
- The latest execution time was Jan 28, 2025.
- Devices. There was 1 device in the latest execution result of the NI. Click 1 and view the device.
- Results. The latest result contained 1 success status code count, which included the device status code count and the intent alert status code count.
- Click 1 to open the tooltip to view the success message.
- In the tooltip, you can see more details.
- Click the success message to open the Diagnosis Details and Compare window.
- Click Overall Config Check to open the detail pane.
- Click 1 to open the Diagnosis Message window.
- History. The latest execution result had alerts.
- Click
to open the tooltip and click the time points to view their execution results in the detail pane.
- Understand its icons.
Icon Indication
The history results contain no alerts.
The latest execution result had a success status, but the historical results contained at least one alert.
- Click
