R12.1 Project-2025/11/05
View CLI Commands
The Automation Insight tab displays the CLI commands.
Example: View the show bgp CLI command.
  • The name of the CLI command is show bgp. Click it to open the detail pane.
  • The latest execution time was June 25, 2025. When there are multiple devices, it displays the latest update time.
  • It has 1 device in total. Click 1 to view the device.
    Information Tip: You can switch to different devices in the detail pane.
