R12.1 Project-2025Sep08
Use the Data View Template
Monitor Metrics History
- From the NetBrain Desktop Management UI, open the desired map.
- In the Data View tab, Select Built-in Data View Templates > LogicMonitor > double-click [ LogicMonitor] Monitor Metrics History.
- Confirm that the Data Source is set to Live.
- Confirm that the objects (devices) are properly instrumented with the expected LogicMonitor data.
Note: Overlay of the LogicMonitor result may take seconds-to-minutes to complete and refresh depending on the number of devices on the map.
- Click table names to review the monitor metrics history result from Data View Result Console.
Troubleshooting
If there are any problems encountered during the deployment or integration of NetBrain with Splunk Enterprise, contact NetBrain Support at [email protected].
