R12.1-2025Jul03
Use Chatbot to Execute Automation
End users can interact with chatbots defined by power users to diagnose network issues without help from a human agent.
  1. Two ways to launch the bot:
    • From the desktop, select   from the taskbar.
    • Receive the bot URL and open it in a web browser, then login to the bot with the NetBrain or portal credentials and start to interact with it.
      Each chatbot has its unique URL. For example, http://192.168.31.46/bot/10000g.
  2. View the welcome page, which includes the chatbot purpose defined by the power user. Click START to go to the chat console.
  3. Start interacting with the bot.
    Operations
    Details
    1
    Click the button to follow the conversation flow.
    You can also enter the button name in the input box.
    2
    Select from the drop-down list to interactively provide input.
    Depending on the power user's configuration, you will make a single selection, or multiple selections.
    Note:
    -You can enter the input in the drop-down box directly if the bot owner enables this option.
    -The custom input for devices is case-sensitive.
    3
    Enter input data or built-in commands in the input box.
    4
     You can view previous sessions and start a new session at any time.
    Every chat session will be saved automatically.
    5
    Publish the current session with important findings to others for collaboration.
  4. View the automation result in the bot.
