R12.1 Project-2025Sep08
Setting Up Combined Access
As shown in the diagram below, monitored accounts on the right-hand side are the accounts you will add to NetBrain for management purposes. You will need to configure the appropriate roles for these accounts to be accessed by the gateway account.
Compared to pure role-based access, combined access uses key-based access to gain entry to the gateway account, providing the flexibility to deploy Front Servers in any desired location.
Follow the topics below to set up the combined access:
