R12.1 Project-2025/11/05
Search One-IP Table and Map Devices
One-IP Table records all IP addresses and their connections in the current domain, including the connectivity between L2 interfaces, Layer 3 interfaces and switch ports. The one-IP table is generated based on ARP and MAC tables when the system builds Layer 2 topology. The One-IP table in the function portal can be used to search and map devices.
  1. Enter an IP address to search for a device, and then click Map to map out the target device and its connected neighbors.
    Information Tip: You can also enter MAC/LAN/DNS names to search devices.
  2. Apply more layers of data views to view more data if needed.
Difference Between One-IP Table in the NetBrain System and Function Portal
The functions of the shared One-IP table in the function portal have some differences compared with those in the NetBrain Workstation in the following aspects:
FeatureSub-featureIs in NetBrain SystemIs in Portal
One-IP TableSearch One-IP table entries
Map One-IP table entries (map single and multiple entries at a time)
View All One-IP table entries×
Export One-IP table×
Resolve DNS×
Delete Entries×
