Search for NCT (Network Control Table)
The current system supports searching Virtual Server tables and NAT (Network Address Translation) tables.
  • Column value: The Search NCT feature supports searching only by column values. Searching by NCT table names or column names is not supported.
  • IP Address: If you search NCTs with an IP address, fuzzy search is supported. You do not have to enter the entire IP address.
  1. Press Enter. The search results are displayed with the matched keyword highlighted.
    Information Note: The search results are listed under the NCT category.
  2. To open the table, click the See Whole Table link in the upper-right part of the table.
    The opened table will remember the search keyword, so by default, it will show records that fit the keyword.
    Information None: The global search and See Whole Table function use different search methods, so they may return different results based on the search terms you enter.
