R12.1-2025July30
Parse Lines
You can add two types of functions, LineByKeyword and LineByVariable, by inserting the original line texts.
To add these functions, go to the Output area and click + Add More > Parse Lines.
You can get the original line texts with the following three methods.
- The line of variable
- The line between two variables
- The line contains keyword
