Other Operations in Incident Dictionary
Some additional operations are offered in Incident Dictionary to help with the creation and management of Hash Tags:
- Export Hash Tags
The existing Hash Tags can be exported by clicking on Export. You can export system-generated or manually defined Hash Tags into a CSV file.
The single Hash Tag can also be exported by clicking on Export on the Hash Tag detail pane.
- Import Hash Tags
You can import the CSV file back into the system after editing. However, only manually created Hash Tags can be imported.
- ‘Save As’ Option
Right-click on a Hash Tag and select Save As to duplicate this Hash Tag.- Only the name and value for Primary Tag will be copied for system-generated Hash Tags. The new tag type becomes Manually Created.
- For manually created Hash Tags, the names and values of Primary Tags and Associated Tags will be copied.
- Hash Tag Settings
Clicking on the
icon can view and modify the JSON file to match Incident Dictionary's logic.
