Network Change Templates
You can save frequently used network change tasks as templates to quickly create other network change tasks based on the predefined templates.
To browse network change templates in your domain:
Click the start menu
, and select Incident & Change > Network Change Template. -
The system provides the following two categories of change templates:
- Shared Templates — contain the change templates accessible to all users in this domain.
- My Templates — contain the change templates that are only accessible to yourself in this domain.
To find the change template you need, use one or a combination of the following filters:
- Device Types — filter network change templates by specified device type (only if it has been defined in the Start node of a network change template).
- Authors — filter network change templates by specified author names.
Tags — filter network change templates by specified tag (only if it has been defined in the Start node of a network change template).
