Creating a Network Change Template
  1. Create a network change runbook.
  2. In this network change runbook editor, click the  icon and select Save as Template to enter the change template editor.
  3. Define the template variables for the change template. See Template Variable for more details.
  4. After defining the Network Change Template information, click Save, select a location in the pop-up dialog, enter a name, and click OK.
