More Functions in ADT
This Chapter will introduce other improvements to ADT.
- Add Data Manually
- Lock/Unlock ADT
- Adjust ADT Column Order
- Add ADT Data with System Table
- Run Intents in Intent Column
- View Intent Output Map
- Debug Empty Cells
- View ADT Execution Log
- Create and Update Intent Dashboard via ADT
- Export Diagnosis Result to CSV Report Based on ADT Column
- Create Summary CSV Report for Intent Column
- Create an Active Command List Based on the Selected ADT
- Export Intent Output Maps in Batch
- Export/Import ADT
- Set Maximum Displayed Lines in One ADT Row
- Enable Auto Intent in ADT Intent Column
- Browse Results of Operations Related to ADT Column
- Remove Empty Wrapper Intent
- Rebuild Intent-related column Group
- Open Seed Intent
- Open Seed ADT
- User Privilege for ADT
- Clear All Table Data
- Share Automation Data Table
- Save Table Style
- Table Settings in ADT
