R12.1-2025Jul03
Modify Target Device
When the Guidebook is opened, it displays the recommended automation tasks for target devices. By default, all devices on the current map will be set as target devices.
You can customize the target devices using the following options:
  1. Select/deselect the checkbox of current devices, and click Apply.
  2. To delete device(s) from Target Devices of the Guidebook:
    1. Hover over a device, and click .
    2. Click Apply.
      Information Note: Deleting device(s) will NOT delete devices from the current map.
  3. To add device(s) outside of the map to Target Devices:
    1. Click +Add Devices.
    2. In the Select Devices window, select devices by the device type, device group, or site.
    3. Click or  to add/delete the device(s) to/from the Devices Selected list. Click or to add/remove all devices to/from the Devices Selected list.
    4. Click OK and Apply.
    5. Information
      Tip: If you want to quickly switch the Target Devices back to the devices in the current map, simply click Sync Device.
