R12.1 Project-2025Sep08
Map a Historical Path
To map a path with the latest calculation result, do the following:
  1. On the sidebar, click Path to open the Path Browser.
  2. Right-click a path and select the Draw Latest Path on Map option from dropdown.
    Information Tip: To map a path with historical calculation results, click the hyperlink of numbers in the History column, right-click an entry according to the start time of calculation and then click Open Path in Map.
