Create a Role
The NetBrain system provides several typical pre-defined roles. See Roles and Privileges for more details. If these pre-defined roles cannot meet your requirements, you can create roles by completing the following steps.
  2. On the System Management page, select the User Accounts > Roles.
  3. Click Add at the upper-left corner. The following dialog opens:
  4. Configure the following settings for the role:
    1. Enter a unique role name, which is case-insensitive.
    2. Add a short description to describe the role.
    3. Allocate a set of privileges to the role.
  5. Click OK.
