R12.1 Project-2025Sep08
Intent Template
The Intent Template tab of the Auto Intent Wizard enables you to select a seed intent to replicate, decide the replication mode, and assign macro variable value as needed. Then this seed intent will be converted to a template. Then, the intent template will be installed and go through decoding in the next step.
