Gapp Center
Gapp Center is a self-contained manager that provides you with a comprehensive view of all accessible Gapp files.
  • Built-in Gapps — contains the pre-installed Gapps. This category is accessible to all users but can only be modified by system administrators.
  • Shared Gapps in Tenant — contains Gapps that are accessible to all users in this tenant.
  • My Gapps — contains Gapps that are only accessible to yourself. You can find your private Gapps in all accessible domains under one tenant.
Working with Gapp Center
  1. In the NetBrain Desktop, Click , go to Map-Based Automation, and then select Gapp Center.
  2. Point to a Gapp file and click the icon to preview it.
    Information Note: You can also right-click a Gapp and select Run it as a Runbook node.
