Export a Map
When you encounter any problem on your map (such as a failure in path calculating), you can export the map file and then send it to the NetBrain Support Team for troubleshooting. Also, you can collaborate with others to deal with network issues through a map that contains the required network data.
The system supports exporting a map file in the following file formats:
