R12.1 Project-2025Sep08
Discovering AWS Network in NetBrain Domain
Follow the steps below to discover the network data model in a NetBrain domain:
- In the Domain Management page, click the start menu
, and open Discover.
- Click Select API Servers to select the API servers (Amazon AWS) you want to discover.
- Click Start Discovery.
Note: To build the data model correctly, NetBrain requires CLI+SNMP access to all virtual network appliances of each AWS VPC, including the customer gateway devices (CGW), virtual firewall instances, and virtual load-balancer instances. Note: To discover virtual appliances via SNMP/CLI, you can specify their management IP addresses in the discovery interface.
