Defining the Planning Node
The Planning node is used to define the approval request to execute the change.
You can define two types of approval requests:
- NetBrain — define and complete an approval workflow in the system.
- External — integrate with an external ticket system and approve the task in the external system.
Tip: Before using this feature, ensure that you have sufficient privilege. See Access Controls for more details. |
Note: Once a Network Change task is approved, the Define Change node will be locked, and you cannot make any changes. |
