Defining a NetBrain Approval Request
  1. Select the Planning node in the runbook.
  2. In the Approval pane, select NetBrain in the Approval System field.
  3. Click Approval Request and adjust the following settings in the Request Approval dialog.
    1. Select an approver from the Approver drop-down list as illustrated in Step 4 of the screenshot.
      Information Tip: If the user you want to select is not on the list, contact your NetBrain administrator to assign the required privilege to the user.
    2. In the Comment field, enter some comments about the approval request.
    3. Click Submit. After the request is submitted, the designated approver will receive an email (if the email setting is configured) and system notification.
