Define Branch
For a complex network, such as a hybrid network including both traditional devices and SDN nodes, multiple branches can be defined by setting different conditions for each branch in a data view template. Every branch of a data view template can reference Supporting Variables to define its independent Variable Settings, Device and Interface Highlight, and Device and Interface Note.
Branch Conditions
The system provides two-tier branch conditions: branch type and branch filter criteria.
| Condition | Description |
| Branch Type | Specify the qualified node type and interface types.
| Qualification | Set more conditions to narrow the device scope based on the result filtered by branch type. |
Note: Only traditional devices or SDN nodes that can meet both conditions can be qualified. In other words, a Data View Template will only be displayed in the Data View pane of a map when the map contains any of these qualified devices or SDN nodes. |
