Manage Index
Index Store (Elasticsearch index) mechanism can support more tenant data, keeping search performance intact in the case of a large number of tenant/domains.
This section covers the following topics:
Creating an Index Store
- Login to System Management Page.
- Select Operations > Index Manager from the quick access toolbar.
- Click Add on the Index Manager tab.
- In the Add Index Store window, define the store name, unique key and description.
| Field | Data Type | Comments |
| Store Name | String | The name of the index store |
| Unique Key | String | The unique identifier of each index model to create a unique index in the database |
| Description | String | Description for the index store |
- Click OK.
Select an Index Store
- Login to the System Management page.
- On the System Management page, select the Tenants tab and click Add.
- Click Advance Options. Then select the desired storage space in the Add Tenant window.
Note: By default, the data is stored in the default store. |
